SOURCE: How do I empty the Drip Pan
Remove the grill underneath the doors. A flashlight helps, look for a plastic pan, it should just lift out. Some of the older models the pan is bolted down. If you still cant find it, slide the refer out and take the panel off the back, some are easier this way.
SOURCE: Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
SOURCE: how to empty drip pan
At the back of the food compartment where the water collects ,there is a drainage hole, this is blocked up,poke a long thin piece of wire or similar and poke it down the hole, this should clear the blockage,
If the water does not drain away then you need to go the rear of the frig and clear the rubber or plastic hose that you will see on the top of the motor compressor. this should solve the problem.
Plz rate this solution.
Thanks. and merry xmas.
SOURCE: condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
