SOURCE: toshiba theaterview
Find yourself a tall good looking guy on the westside to take your mind off the TV.
SOURCE: TV WILL NOT TURN ON BUT VIZIO LIGHT IS ON
The Service Plan from Walmart is an "extended plan" on top of the manufacture warranty. Your Tv is still under warranty from the manufacture.
Here's a link to get the info you need to get started on a warranty claim:
http://www.vizio.com/support.aspx?id=1588
SOURCE: Turn on JVC 32
There is a way to reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it. If i remember correctly you unplug the tv hold power button for 5 sec on tv then let go plug in and start. If that dont work unplug and then plug and hold power button on tv for 5 sec. It is 1 of those combinations. My tv worked after that. I googled my problem and a website listed that some tvs need to be reset.
SOURCE: 32" ALBA 15 MONTHS OLD.
I am afraid it sounds as though either your backlight or power inverter has gone faulty, may be worth contacting alba to see if they will honour the warrenty (unlikely but worth a go) otherwise maybe try your home insurance to see if its covered, failing either of these options, if you feel confident doing so, disassemble the tv and look for any signs of visible damage (capacitors leaking or any components looking burned or scorche, and replace. Try looking for any panel markings which will allow you to search for a price to replace the whole unit.
Unfortunately I cant give you and hard and fast cure, and it is very difficult to tell whether it is the inverter or the backlight has gone (having said that, if you are getting picture at the very beginning, it may suggest that the inverter is getting the power to the backlight ok, which may suggest its the backlight at fault.)
Hope this helps.
SOURCE: tv is on with no picture or sound, only 4 months old!!
Hello
The power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
Testimonial: "ty :) "
