SOURCE: nortel t7208
it seems like your system does not have disconnect supervision. set it to yes under trunk line data. that way the system knows when a call is released.
sean malone
SOURCE: "flash busy" message when trying to retrieve voicemail messages
It is telling you that the voice mail ports are busy and can not take another call in to the voice mail system. If the port the does not clear up after a min or two then reset the voice mail system . Unplug the power cord from the wall and let it set for a min , then plug it back in and wait about 5 min for the system to come back up , that should free up the ports .
SOURCE: Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
SOURCE: checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
SOURCE: I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
