SOURCE: panasonic kx-t7453, night mode message programming
Do you mean have calls transferred to voice mail? Go into system programming and change 408 (DIL 1:1 Nite) to point to the ext of the voice mail port, which depends on your system. That number is found in 118
SOURCE: how do you switch out of night mode on the
It may work on all phones, but from the main phone on the intercom dial *780x where x = 0/1/2/3 for Day/Night/Lunch/Break.
It can be programmed to work from any phones in the sysetm by class of service.
Carl
Testimonial: "Thank you Carl!!! It keeps switching randomly. Thx again."
SOURCE: how do I change name
From the phone connected to Jack 01 or the authorized phone (generally 101) press PROG and dial **1234 Dial 004 and ENTER and dial the ext number of the phone you want to change Use the keypad to enter the name (you have Upper and Lowercase letters) and the arrow key to step to the next character. When you finish, press STORE.
Carl
SOURCE: kx-dt333 phone rings, red light
You can press the softkey under RingOff and the up arrow on the Navigator button, or just press the up arrow on the navigator button two times. The display will show the ringer volume level as you continue to press the up arrow.
Carl
SOURCE: How can I set the number of rings on our Panasonic
it's best to have your local panasonic dealer/serviceman do it, because it will require you to know the installer programming password which the installer sets, and it requires you to know the inbound call paths so you set the correct timer (all very simple if you have a computer hooked up and own the programming software, but a pain if you are trying to program through a phone)
