Check to make sure there is no food left at the bottom of the rack, then check to make sure you are adding the correct dishwasher soap that Samsung recommends to use with the dishwasher. If this is not working you could try using heavy duty dish washing cycle or try rinsing off your dishes before placing them into the dishwasher this reduces food buildup at the bottom of the dishwasher and helps clean your dishes better
SOURCE: Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Very common problem is soap build up in these machines. Try putting it into a wash cycle with no dishes, and no soap. Let it wash for about 5 minutes, and then open the door. If you see alot of soap suds, then soap build up is the problem. Try doing a couple loads with no soap, and no dishes, and throw a cup of vinegar into the machine halfway through the wash. Repeat as necessary. This should solve your problem.
SOURCE: SHU43C06UC dishwasher cleans dishes on bottom rack
your top spray arm is blocked and not rotating,remove it from top basket and thoroughly clean it paying particular attention to the holes right at the ends these are angled to drive the arms round if they block up the arms will not rotate.
SOURCE: dishwasher leaves food particles on dishes
You are not getting enough water in the machine. The inlet valve is probably plugged with sand or something of the sort. You will need to replace the inlet valve.
