Anonymous Posted on Nov 25, 2007
Sony "Protection" mode - STR-DE725
I have a Sony STR-DE725, which will click into "Protection" mode after 1 second to 5 minutes of use. I've tried cleaning it out, looking for any loose wires, etc. Nothing. Now even when I just plug it in with no connections, the problem still happens. Any ideas?
  • 1 more comment
  • Anonymous Jan 01, 2008
    I hooked up a Niles SS-6 speaker selection system to my Sony STR-DE725. The Sony went into "Protection" mode. I disconnected the SS-6 but the Sony remains in "Protection" mode. How do I get it out of protection mode? Already tried unplugging the system.
  • InLosAngeles Jun 15, 2008
    STR-DE725 has "Protector" on flashing after I purchase it from a second hand store anyone can shed some light ?? Thank you..
  • Anonymous Mar 09, 2009
    HOW TO TAKE THE "Protector " sing out from Sony STR-DE725.
A
Anonymous
My sony used to do that to umm cant remember the model but yeh i could play it at low volume but as soon as i turned it up it would start clicking and telling me to turn of the power...
I resolved it by checking every cord connected to it, it turned out that because I connected two speaker cables together i didnt seal it properly and they were touching this was making it go into protetion mode.
My Sony str de335 is in protection mode speakers are unhooked how do I get it out of protection mode?
if you disconnected everything and it still goes into protect, the most likely there is a damaged amp channel that will need to be repaired.
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
I am thinking of buying a SONY STR DE725 (QS Series) AV receiver. I alreay have a set of home theater speakers with 5 x 80W 4 ohm and and active Sub-woofer (200W). I am wandering whether the receiver...
Yes, it will support a powered subwoofer.
If your existing speakers are from an all-in-one Home Theater in a Box and they have molded connectors you'll have to chop them off to make the ends bare wire and determine which is plus and which is minus on each. Loads of 4 ohms may present a problem at high volume levels.
Take the rated wattage of the sub and other speakers in an HTIB with a HUGE grain of salt. They plays numbers games with th low impedance and the allowable distortion levels to get the results they publish.
For all anyone knows, the speakers and their original electronics may have been designed to operate together to yield adequate performance (like Bose does). Breaking that pairing may give unpredictable results and risk of damage to the speakers or the new receiver.
1helpful
I don't get any front display or any sound when turned on.
Do you hear any clicks? If not, the standby transformer or related circuitry is bad. If you hear 1 relay click...the audio output section is most likely the problem. The first click you hear is the main power relay...and should see display.. the second relay click is the protection circuit relay engaging to let audio to your speakers...if the second click is not heard (it should occur in 3 to 5 seconds) there are shorted output transistors or a shorted output IC trying to blow your speakers with 50 to 75 volts dc. The protection circuit monitors the speaker lines for voltage. They should always read milli-volts only...not even 1 volt.Anyway, good luck
2answers
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
