First, I'm not a Zanussi tech.
* Check your warranty and call for service.
* Red light is High Temp warning.
* Repairs must be performed by a certified refrigeration repairman.
*** The following is for information only ***
* Sales info; https://www.youtube.com/watch?v=rwKM0YAIK8Y
* Freezer Review; https://www.youtube.com/watch?v=MQSCHvVjzcU
* Trouble; (simpler); https://www.youtube.com/watch?v=duTWh83nVdA
* Troubleshooting (very Detailed and Technical); https://www.youtube.com/watch?v=ia183A8VT5M
* Be safe, call for service.
Aloha, ukeboy57
SOURCE: Icing up in bottom of the freezer
machine has a defrost issue, defrost mi metal or defrost timer
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
SOURCE: frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
SOURCE: Zanussi DF62/21FF frost free fridge freezer is beginning to ice up? Please help. Thanks.
thermostat or defrosting element
SOURCE: BEKO Frost free freezer not as cold as it should be!
Sorry I don't have a solution for you, however would like to know if you found out what was wrong. I have an identical problem with my Beko fridge/freezer. It's only 14 months old and the freezer just wont freeze. I've turn it off for 24 hour and let it defrost completely (even had the panel off to make sure there was no ice left). I've turned it back on again and it still wont freeze. Everything seems ok, ie fan blowing, motor running etc. I really am beginning to regret buying Beko. thanks
