SOURCE: Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
SOURCE: Carrier Air V in RV not working - 5 green blinking lights error
Call 1-866-464-2478, Mon-Fri, 8am-5pm. Have model numbers of lower (inside control box etc) and upper unit ready, and I'd ask for technical assistance. Good Luck.
SOURCE: Red Light Flashes twice KDF-E50A10
I just went through the same problem. I replaced the bulb myself and when i put it back together it turns on then goes out. I had 3 red lights. i checked the trap door and the lamp assembly many times and it wasn't that. I finally took it to a repair place and they told me it was a power supply issue. $200.00 total to fix. Works fine now.
Hope this helps a little...
SOURCE: Marantz SR6001 AV Surround Receiver - Blinking Standy Light
I have exactly the same problem! Sometimes when I turn the input dial it comes back on but this time it is out for good. I have tried re-wiring and unplugging etc. nothing seems to work.
SOURCE: Sunbeam KY-25 portable air conditioner not working.
the problem im having is ,when the compressor starts it goes off after 2 seconds....the fan still works....it has been sitting around for 3 1/2 tears...any help would be great.....thanks....i just dont want to bring it to the shop
Hi Tom Rush, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
