Tadalista 20mg Buy Tadalista 20mg Online, Tadalista 20 side Effects , india
SOURCE: pride jazzy 600 power wheelchair controller lights flash
make sure the motors are not disengaged, turn off chair, can you move it by pushing it? if so lock the wheels and try again. next is the controller in lockout. press and hold the on button till it beeps push joystick forward til it beeps pull it back til it beeps turn off try again. you can call 1-800-800-8586 for tech support
YOU MAY HAVE A LOOSE WIRING.
There is a 51 page MANUAL here:
Quantum 6000 Owner Manual
See this link for 1,500 Troubleshooting results:
quantum 6000 wheelchair troubleshooting Google Search
You may be looking at a sudden/intermittent electrical short OR one of your connectors may be loose?
http://www.thewiringbooks.com/wiring/quantum-6000z-wiring-diagram.html#gallery-1
Your chair voltage REGULATOR may also be going bad which appears to be WITHIN the "Main Brain" of your chair?
"TECO FM-50"
From the above schematic ~ there is a "Potentiometer" shown (lower left) that MAY be 'dirty' and needs a tiny squirt of "QUALITY" contact cleaner WITH SILICONE to help keep the internals clean... looks something like this (a Google Search):
I would also spray ALL of your control switches too including the inside of your joystick controls! Just a REAL QUICK squirt should do it... if it drips, you've used too much.
I hope this HELPS YOU!
Anthony
