Question about Stoves Ovens
I have a gl616 stoves new home gas cooker. How do I get the oven and grill to work ? There is gas to the rings ok. When I turn the dial to grill or oven the fan comes on but it wont light.
I have a gl616 stoves new home gas cooker. How do I get the oven and grill to work ? There is gas to the rings ok. When I turn the dial to grill or oven the fan comes, it sparks but it wont ignite.
    Top Expert:
  • Stoves Master
  • 10,030 Answers
Bad ignitor
Posted on Sep 01, 2018
5 Suggested Answers
SOURCE:
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
SOURCE: i have a rangemaster 55
mine has done the same thing boxing day. Did you get a solution
Posted on Dec 27, 2010
  • 250 Answers
SOURCE: I have a stoves cooker
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Posted on Aug 20, 2011
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Touch control not working on aeg d98000 cooker
I'm afraid you have a bad board. I had a neighbor with the same problem and he had to replace just the stove top part. Hopefully, yours is just the temp setting part, but it may not be that if you can control the oven setting.
Feb 24, 2013 | Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
Jul 31, 2011 | Stoves 720EF Electric Double Oven
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
I have had 3 engineers out to try and fix my stoves 720gra cooker and has changed all the printed circuit boards ,and all other parts but still the top oven and grill doesnt work and has now been classed...
check the voltage on the spark generator,should be 240dc or 110 ac.
or it could be the harness(wires fron spark generator to ignition) to check harness do a continuity test,an electricion will know,or get a electirc tester and do it with the instructions.
Oct 01, 2009 | Stoves Premier 720GRa Gas Double Oven
How can i mend the grill and oven on my electric cooker?
Hope this helps.
Thanks.
Dec 31, 2008 | Ovens
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
131 people viewed this question
Top Stoves Ovens Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Stoves Oven Expert? Answer questions, earn points and help others
