As the old organ tech saying goes, you can attach a Leslie to anything! I couldn't find an online manual for the Prestige, but I would suggest finding the nearest experienced tech in your area to do the job. If there are non you are available, follow the link below to the Musical Instrument Technician's Association page for a directory.
SOURCE: Warrenty
If it was fitted by an installer after July 1st 2007, then it's covered under warranty for 3 yrs, but if it was purchased then installed by you I'm afraid it's only one year :(
Having said that, if you are sure that the speaker blow due to faulty manufacture, Focal has a really good PR relationship with focal dealerships, and you could ask for the Focal representitive to inspect the midrange.
It's a bit of a long shot, however being Focal they like to keep the excellent reputation they have intact, and I've been able to replace a pair of Focal tweeters in the past (due to faulty manufacture) even thought they were almost 3 years old.
Unless things have changed somewhat over the last few years, they should still have a subjective approach to their warranty claims...
Well....here's hoping anyways!!!
SOURCE: Speaker problem
Don't know if you've solved this yet but just in case ...
There is nothing to install with loudspeakers - they are independent devices and have nothing to do with your computer.
Check the little lights. There should be one on the back of the subwoofer (by the power switch) and one underneath each of the satellites. If you haven't got the lights under the satellites then you probably have a faulty subwoofer. Check thought that your connections are solid. Remember the two satellites' connectors are keyed and may not be fully home, rotate them slightly until they click completely in.
Theses are excellent speakers and should be deafeningly loud.
SOURCE: Have a Durabrand Model PDV-705 7
Well Durabrand is a walmart brand but fry's sales these external batteries that will hold alot more play time then it would to replace this for a new battery. And the cost is $49.00. You will get extended play time for the fraction of the cost of replacment batteries!! I hope this does help you out.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: Lowery Tube Organ needs a tube
The "F" key contact is probably stuck on rather than a tube problem. It MAY be a mechanical thing OR it could even be contamination such as a staple or paper clip that has fallen into the key area. Look for something obvious around the key contact. Most any competent electronics person should be able to fix this one.
SOURCE: no sound is coming from my external computer
Hello....
No Sound, No Volume Control, Mixer not Found, No Sound device installed…etc etc, This is a generic issue with all Windows OS updates....many of the users are facing this issue....this issue began after an auto update from MS changed many IRQs of Win OS, mainly the Sound and Audio Control system of Windows.
1 - R U facing NO Audio / No Sound issue...?
2 - Is ur Volume Control not responding ?
3 - Is ur Sound and Audio Device in Control Panel Grayed out ?
4 - Do u get a msg "No Active Mixer Devices Installed....when u try to open Volume Ctrl etc etc ?
If ur ans to any one of them is Yes...then u are being spammed by Microsoft....as ur Sound Control IRQ is being frozen by a recent update from Microsoft....
NOTE..THIS…IS…VERY..IMPORTANT...
No file update or any sound driver update can fix it, neither Microsoft is issuing any patch to fix it…or giving any help on this.
Full solution is available in my website (Support page)...it's quite simple process to fix it, and I am not charging any money, just trying to do some service and help everyone affected by this stupidity from Microsoft.
www.sureshayyar.110mb.com
visit my support page.
all the best...
