SOURCE: blinks and doesn't heat.
Could be a loose connection or a damaged cable. Try gently moving the cable and see if it starts to blink etc?
How old is it? Is it still in warranty Guarantee? If it is, take it back to where you bought it from and they should repair it or replace it.
Failing that you may have to buy a new one. Wallmart or similar have cheap electrical appliances
SOURCE: My iron shuts off when I am continuously ironing.
The flashing is a indication that somthing is failing.. More than likely it is a internal component..
It might be most efficent to get a new one..
Or bring it back if it is under warranty..
Good luck..
SOURCE: Hamilton Beach Ultra Steam Iron Model #15410
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: i have hamilton beach iron
Here is the link to the manual, I would suggest checking that out first.
http://useandcares.hamiltonbeach.com/files/840164300.pdf
SOURCE: water leaking out of iron
The Use and Care Guide for the Hamilton Beach Iron can be downloaded here:
http://useandcares.hamiltonbeach.com/files/840091300.pdf
If water is leaking out of the iron:
• Do not overfill the water tank.
• If steam ironing, is Adjustable Steam Knob in a steam position that matches Temperature Control Dial steam range? Did the iron have enough time to preheat?
• If dry ironing, make sure the Adjustable Steam Knob is in the DRY IRON position.
