Before buying myself a watch, for a long time I was choosing user manuals from my catalog http://manymanuals.com , you can also see information about different Cassio models
SOURCE: inhereted watch,how do you cancel alarm?
Go online to the Casio site, select the manual and read instructions.
SOURCE: i have wave ceptor 2734 watch strap needed
I have a similar watch and as far as I can see a standard watch strap can be fitted.
Go to your nearest watch shop and ask if they can fit one for you.
SOURCE: How to set the hands to match the correct digital
Setting Digital Time
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
