SOURCE: '96 Toyota 4-Runner makes a loud squealing noise and brake light
Sounds like one of the auxillary belts slipping it may just need tightening up. I think the 4-Runner has two belts one large and one for the steering pump
SOURCE: e39 starting issues
HAVE YOU HAD THE BATTERY TESTED? ARE THE BATTERY TERMINALS/CABLES CLEAN AND FREE OF CORROSION? ARE THEY TIGHT?
SOURCE: 06 jeep commander wont crank. No interior lights,
Check your battery cables. Remove them and clean the contacts, if the ends are replacements take them apart and clean. Use a wire brush or sand paper. Make sure you remove the negative first and reinstall it last. Also check the battery and fuse links. Your problem is in there some where the battery, cable ends, cables, or a fuse link. If still no start let me know the results and we can go from there if need be.
Testimonial: "Ron, thanks for the help. I had already done what you had listed. I cannot figure out how it could work and then not work 20 seconds later "
