Question about Retail Supplies
Is metal detector can detect stainless steel?
    Sergeant:
  • Retail Supplies Expert
  • 190 Answers
Like steel, stainless steels are relatively poor conductors of electricity, with significantly lower electrical conductivity than copper. Ferritic and martensitic stainless steels are magnetic. Annealed austenitic stainless steels are non-magnetic. Work hardening can make austenitic stainless steels slightly magnetic.
Best Metal Detector In 2017 Tested Reviewed by Detecting Expert
Posted on Jul 02, 2018
6ya staff
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: stainless steel appliances ie. refrig, dishwasher & oven
a quality s/s cleaner and a clean cloth sould do the trick for most stains, WD-40 also works to remove the stains, works really well, also leaves afilm on the metal to prevent stains from adhering, just dont use paper towells, the tend to leave fibers behind. and also look closely at the s/s there is a GRAIN pattern in the metal just like wood would have a grain!! be sure to wipe in the direction with the grain not against.
Posted on Mar 19, 2008
Anonymous
SOURCE: scratched stainless steel
First, I would not use ordinary steel wool. Small microscopic iron particles get embedded in the stainless steel surface and could lead to rust. There is stainless steel wool, but I have experience using sand paper, so I'll tell you about that.
When changing a faucet, thinking it wouldn't harm a stainless steel sink, I used a kitchen knife to scrape that crusty residue left from hard water. I had put in several noticeable shallow scrapes on the top part of my sink where everyone could see it.
I used a series of silicon carbide, wet/dry automotive sanding paper to hide my blunder. First 400 grit, then 600 grit, then 800, then 1000. The 1000 grit was actually to "polished" looking so I went back and finished with 800 grit, blending the refinished area out to the rest of the sink top surface. I sanded in the direction of the surface graining.
For your backsplash, the type of finish will determine what grit you'll finish with. If is it polished to a high lustre, then you'll have to go to finer grits. If it is polished to a mirror finish, then you'll have to eventually finish with a polishing compound.
While working on my sink, I had gravity to help me put weight behind my work (so to speak), but on your backsplash you'll have to awkwardly push sideways to work the sand paper, plus you may have cabinets in the way and a hood to clunk your head into. Depending on how much trouble it would be, you may find it easier to remove the backsplash.
I you are not familiar with finishing metal, you could practice on a piece of sheet metal first, getting used to how much pressure to apply, and sanding in straight strokes so you can match the backsplash's surface graining. If your backsplash has a mirror finish, you could try a polishing disk on a drill or a dremel tool first.
Posted on Oct 02, 2008
Anonymous
  • 92 Answers
SOURCE: installing stainless steel sink with metal clips
if you look at edge of sink you will see small rail the bulbous end of clip goes in rail and flat side of clip goes against under side of countertop you then tighten clip which will pull sink and counter together you should install with plumbers putty around rim
Posted on Mar 25, 2009
DeBruce
Bruce
  • 145 Answers
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
use scotch brite #7447 get at automotive stores and blend scratches with the grain. If they still exist use 180 to 240 grit sandpaper and again finish with the 7447
Posted on Aug 24, 2009
meganhaskins
Shawn Hudson
  • 190 Answers
SOURCE: Is titanium detected by metal detectors?
The most commonly implanted orthopedic materials include stainless steel, cobalt chrome, and titanium. Different types of metal detectors work in different ways, but the newer airport screening detectors will identify patients with these metal implants. Obviously, there is nothing you can do to change this. Diggers Pouch Camo Review Detectorly
Posted on Mar 21, 2018
What metals do not set off a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Elenco Metal Detector With Beep Alert Review Detectorly
May 07, 2018 | Retail Supplies
What metals can be detected by a metal detector?
Non-Ferrous metal is non-magnetic metals (copper, aluminum, brass, lead, etc.) It will take approximately 50% more of a non-ferrous metal to be as detectable as a ferrous metal. Manganese is also a non-ferrous metal and difficult for most metal detectors to detect. Best Underwater Metal Detector In depth Guide Reviews For 2018
Apr 11, 2018 | Retail Supplies
Do metal detectors detect all guns?
no
it cannot detect plastic guns or 3d made guns unless the bullet is in the gun
It is called a "metal " detector
Mar 22, 2018 | Vehicle Parts & Accessories
Mar 21, 2018 | Retail Supplies
How deep do most metal detectors go?
If you are looking for gold or other precious metals that are buried deeper than one meter, you need a 2-box metal detector. Unlike traditional coin detectors, which are made to find smaller individual items, a ground two-box metal detector can penetrate the earth using special search coils that transmit signals. https://detectorly.com/key-things-consider-purchasing-metal-detector-beach
Mar 15, 2018 | Retail Supplies
What is a good metal detector?
A metal detector is an electronic device which detects the presence of metal nearby. Metal detectors are useful for hunting metal inclusions hidden within objects, or metal objects buried underground.This is the depth to which your metal detector is able to search for coins and other objects. A good metal detector has a sensivity that is the ability to detect metal objects from a distance. Lower frequency detectors offer better depth.You can usually find coins to a depth of one and a half times the search coil diameter. https://detectorly.com/ever-wanted-know-metal-detectors
Dec 16, 2017 | Retail Supplies
How do I operate this metal detector
umm. which metal detector would that be Andrew?
Apr 08, 2017 | Retail Supplies
Can you buy one metal detector that does all different types of detecting?
In most cases, one metal detector will do it all except for specialized situations. So nugget detectors and underwater ones wont be good for more geneal detecting.
Feb 21, 2013 | Retail Supplies
Can you do metal detecting under water?
Yes, metal detecting under water is actually quite popular. There are a few types; Snorkeling with a metal detector, Scuba detecting and Shipwreck diving.
All of these types require equipment that can be expensive to hire/ buy.
Retail Supplies Logo
90 people viewed this question
Top Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Retail Supply Expert? Answer questions, earn points and help others
