Refrigerators Logo
M
Michael Chidiac Posted on Jun 30, 2018
I have an Allvino wine fridge and it started to beep and stopped cooling
I purchased this fridge (80 bottle) in 2013.
5 Related Answers
A
Anonymous
  • Posted on Jul 04, 2008
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
Anonymous
  • Posted on Aug 04, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Anonymous
  • 205 Answers
  • Posted on Oct 14, 2009
SOURCE: our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Anonymous
  • Posted on Mar 24, 2010
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
Anonymous
  • 27 Answers
  • Posted on Aug 07, 2010
SOURCE: Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
My Wine Enthusiast fridge stop working, the front panel is blinking.
Question edited for typo.
Question moved from Furniture to one of the Wine Enthusiast categories.
Try a Power Reset. Disconnect from the wall plug. Wait 5 minutes and plug back in. If that doesn't fix it, you need a service call. They have a history for control board failure.
Page 6 in this manual says it is indicating accessibility to settings.
http://static.appliancesconnection.com/attachments/D569d6dc555d6e.pdf
More here, including videos
https://www.google.com/search?q=wine+enthusiast+n%27finity+pro+wine+fridge+control+panel+blinking
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 • Furniture
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Fast start option does not work
I'm not sure how you ended up under this classification;
All Products > Oster > 12-Bottle Wine Cellar - Black > Troubleshooting
but your problem with an undescribed brand and model will not likely ever get a response.
I think your question is in regards to a microwave oven. Try reposting it with the correct brand and model #.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
