Question about Konica Minolta bizhub Office Equipment & Supplies
My bizhub c353 wouldn't print. Displays error code FC2B. Any help?
  • Konica Minolta Master
  • 6,850 Answers
Replace MFB board
Posted on Mar 03, 2019
SOURCE:
Kevin Hayes
  • 167 Answers
SOURCE: Printers with full bleed capability?
NO!
Just like on a printing press that toner is being imaged somewhere when it runs out of the sheet. The toner is going on the imaging belt/fuser. Over time it will build up and ruin the device. On a press they can stop and wash the imaging blankets. Full bleed is achieved by running on oversized stock and trimming off excess afterwards. That is how the "Pros" do it.
Posted on Apr 27, 2009
taminol
  • 62 Answers
SOURCE: Minolta Bizhub C353 fails scan to emails
Hi mmarsh1212,
When you say the bizhub fails Authorization, do you menat it fails Athentication?
If so, and I pressume your technician knows what he's doing, you have an issue with a password. I suggest you create an address for the bizhub on your email server and then re-setup the scanning to email credentials via the web browser direct to the machine.
Let me know if you need help with doing this.
Regards
Taminol
Posted on May 26, 2009
  • 95 Answers
SOURCE: WHY IS THERE A BLINKING ORANGE LIGHT ON BIZHUB
That is not much to go on, but it is possible that the print job got sent to the wrong tray. Say you printed a job to tray 2 which has legal paper in it, but the job is formated for letter it could lock down printing until the job is canceled and sent to the right tray. If there is an error code try and shut machine off and on using the main power switch inside front door.
Posted on Jun 04, 2009
  • 158 Answers
SOURCE: adding an IP address to Bizhub C353
at the copier press the scan button touch direct input tab,touch scan to smb, in the host name field enter the tcpip address of the target pc, in the destination folder enter the shared folder name, in the user id field enter the valid workgroup or domain user name, in the password field enter the user password, press start. at the computer you have to create a shared folder on the root of c: and give it all rights read and write allowed this is how to scan to a shared folder you can also sca to an internal email server or to a ftp server on your network or to a usb flash drive that you can plug directly into the machine
Posted on Oct 03, 2009
SOURCE: Have a bizhub C353 conected to a network. Using a
have a bizhub 250 trying to scan to pc via smb on a network. Keep getting login failure. Can you help
Posted on Feb 15, 2010
HOW CAN I OPEN THIS CODE IN MY PRINTER, C-FC2B
What is the model number for the machine?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 19, 2014 | Konica Minolta bizhub Office Equipment &...
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Feb 08, 2014 | Konica Minolta Bizhub C353 Copier
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
I have Konica Minolta bizhub C353 and the paper keeps getting jammed after several prints. I just cleared code error c-3421 but it keeps getting jammed. Any help.
First Are informing the copier of the proper paper weight
? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also.
Oct 10, 2013 | Konica Minolta Konica Bizhub C353 Drum...
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
Nov 12, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
50 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
