SOURCE: Yamaha psr e313 can't switch on. The adapter is
Check that your power adapter is 12 volts DC AND MOST IMPORTANT is the center pin is positive... this is reversed of MANY adapters used for pedals, etc. The current rating should be around 1.5 amps. Don't take another techs word for it... check it yourself.
Does it ever turn off?
The PSRE313 uses a rubber on/off switch with a carbon dot on the underside that does wear out. If all is working well I would suggest replacing this rubber switch part number WD893400
