Exercise & Fitness Logo
J
John lucas Posted on Jun 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Exercises for elderly people to help stability
Marvin
Level 3:
Top Expert:
  • Exercise & F... Master 85,242 Answers
  • Posted on Jun 29, 2018
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29056948
Points
266281
Walking is number one or swimming
1 Related Answer
Anonymous
  • 195 Answers
  • Posted on Jun 21, 2010
SOURCE: Teaching computers to the elderly
May seem strange but I would recommend playing Solitaire.
1helpful
What are the different ways to prevent shin splints pain?
Here are the different ways to prevent shin splints pain:
1. Strengthen your hips- The best exercises for preventing shin splints are basic squats, deadlifts and lunges. But, your focus should be on using your glutes.
2. Minimize using machines- Machine based exercises are some of the least effective for treating shin splints. The reason is because most machine-based exercises are performed while sitting down and in an apparatus that provides all of the stability for you.
When you run you're standing not sitting. So, your own body has to stabilize itself as you are on one leg the majority of the time. If you aren't training the actual movements and positions similar to running then you are making yourself prone to injuries to your shins, ankles, knees, hips and lower back.
3. Stop running on the treadmill- Treadmills are a great piece of equipment to run indoors or while you watch TV at the gym. But, if you are trying to avoid shin splints then you'll want to avoid the treadmill as much as you can and run on a solid surface instead.
Treadmills operate with a belt so it's harder to get a solid push off the ground because it's moving underneath you. When you run on a solid surface like outdoors you can push off the ground which also helps activate the hips more effectively than on a moving surface.
4. If using a treadmill use incline rather than speed- If your only option is using a treadmill then keep the speed down a bit from your normal pace and substitue by increasing the incline slightly.
Running on an incline can help reduce shin splint pain because you naturally have to push off the ground harder using your hips to move uphill. When running on a flat surface your shin muscles can take over since the hips aren't forced to work very hard to move your body.
5. Use effective training combos- There are a number of exercises and sequences that can help you prevent shin splint pain if you know how to do them.
2answers
What are some exercises I can do using an exercise ball?
Here is a list of over 40 exercises using an exercise ball with a description and picture of how to correctly execute each.
http://www.ball-exercises.com/exercises/index.html
I just bought an exercise ball for my home gym. Are there any good beginner balance exercises I should master before integrating it into my regular workout routine?
That is a great question that most people don't consider. Starting to use an exercise ball changes the way you work out. It is very important that you understand how to properly balance on the ball first. I found you an excellent website that will show you some basic exercises to help increase your balance and stability.
http://exercise.about.com/library/blbeginnerball.htm
2answers
How many different Exercise Balls are they?
There are plenty of Exercise Balls each serves for a different purpose. Including balance ball, birth ball, body ball, ball, fitness ball, gym ball, gymnastic ball, Physioball, Pilates ball, Pezzi ball, sports ball, Swedish ball, stability ball, therapy ball, or yoga ball.
What are foam rollers used for?
Foam rollers are used for all sorts of exercise, includingstretching, self-massage, body support, and stability exercises.
What are foam rollers?
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
