GPS Logo
Emoh Ruo Posted on Jun 29, 2018
Navman touch screen not responding - Navman GPS
Reset with no disc etc
SAT NAV - RESET PROCEDURES FOR GARMIN, NAVMAN, TOM TOM
Updated 08/05/2014 05.01 PM
Reset Procedures for Garmin, Navman, Tom Tom
Garmin Master Reset NB: This will erase all way points or favourites and will restore your unit to the default factory settings.
Nuvi® 2xx, 2x5, 5xx, 6xx, or 7xx.
  1. Start with the unit OFF and unplugged from power.
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil.
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON.
  4. Release the power button when the device powers ON.
  5. You will see a new message: Do you really want to erase all user data?
  6. Remove your finger from the touch screen when this message displays.
  7. Touch Yes.
The device will automatically reset. Please follow the on-screen prompts on the n?vi and when completed, place your device in an area with a clear view of the sky until it acquires satellites.
Nuvi® 8xx or 5000.
  1. Turn the device OFF (you will need to remove the battery from a nuvi 8xx).
  2. Turn the device back ON (you will need to install the battery into the nuvi 8xx).
  3. When you see a progress bar on the screen of the unit, quickly place your fingertip, or the eraser end of a pencil, in the bottom right corner of the touch screen.
  4. Hold the bottom right corner of the touch screen until a message says, "Do you really want to erase all user data?"
  5. Release the touch screen and touch Yes.
  6. The unit will now restart.
  7. Follow the onscreen prompts to set up the nuvi.
Navman S30/50/70/S80/90i.
  1. To reset your device, hold down the power button for at least 10 seconds and the device will power off.
  2. Press and hold the power button to turn the device back on.
For other models, please visit this link, select model and search for 'reset'.
TomTom
  1. Soft reset - select your model.
  2. Reinstall TomTom application.
  3. Format internal memory or memory card.
Navman problem
WHY is it suddenly, overnight, my Navman EZY 45 has gone from working perfectly to the touch screen hardly working at all? All the buttons have moved ie: You CAN'T touch on the button you want, you need to touch either the one above or below it. As for the Accept and address buttons, well that's just not happening, back = Q and so on.
I have formatted, reloaded maps, done everything Navman has suggested. Is this a Hardware issue? If so, a rarely used 15 month old unit will be going in the bin and I will compare other brands.
Any help appreciated as I love this small but great unit.
Cheers
Jan 02, 2014 • GPS
How can i change my navman from German to English. Thank
  • Press the "Main Menu" button on the Navman to bring up a list of options. Tap "Preferences," choose "Localize" and "Language." Each option is selected by touching the screen. The different language options show up on the screen in list format. Touch the language you want to use and press the check mark icon. The Navman will now operate in the chosen language.
  • 1helpful
    I have a cracked touch screen My &%T can it be
    Welcome to FixYa!
    Yes it ca be replaced. Go to Satellite Navigation Repairs for qoutation. Click the link below. http://satnavrepairservice.com/repair-satnav/navman-repair/14.html
    Thank you for using FixYa. Have a great day.
    Jas247
    2helpful
    I purchased a NAVMAN S-150 GPS In-Car Unit last week from ****-smith online shop. I have been testing this device for several days now. Why is it that the various touch screen buttons respond differently...
    I have the same problem, the s150 touch screen is pathetic, Got the same story from Strathfield Car Radio..it was normal and had it in for repairs twice when the screen went crazy with vertical lines, same fault both times. I went back to using my s50 and will sell the s150, it is a highly complex, very pretty lemon. They wont refund you or give map upgrades for inconvenience caused by their faulty product. To sum the s150 up. A truly Miserable experience. Rate it out of ten? its a minus.
    Graeme
    Nov 21, 2008 • GPS
    Problem with my Navman s50
    hmmm..sounds like you are suffering from a firmware issue..have you downloaded any updates recently?
    Mar 22, 2008 • GPS
    6answers
    Navman f10
    i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
    [email protected]
    Touch screen not responding when using stylus.
    Is it just possible you left the Navman mounted on the screen in hot weather whilst away from the vehicle? I made a little white jacket for mine with a heat reflecting liner.
    Not responding......help
    Low or flat battery. Connect to mains charger and fully charge.
    Top Navman GPS Experts
    ZJ Limited
    ZJ Limited
    ExpressFiX
    ExpressFiX
    Mike Cairns
    Mike Cairns
    Are you a Navman GPS Expert? Answer questions, earn points and help others
