All plugged in, no sound no picture
SOURCE: Surround sound from Sky +
To upmix 2-channel sound (such as that in a TV broadcast) into 5.1 sound, press AMP and then SUR. DECODE until "PL II Movie" is displayed. This will give you "cinema-like" surround sound from a 2-channel source.
You can also assign this to one of your "Scenes" by following the procedure for scene assignment on page 26 of your manual.
SOURCE: PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
SOURCE: I have a Yamaha Rx-v363
this sounds strange, but is true. you need to run your digital audio optical cable from your tv to your receiver (after, of course, connecting tv/receiver via hdmi). so, hdmi from blue ray to rec - hdmi from rec to tv - then optical from tv back to rec. it's round about, but that is how yamaha says (and the only way it works) to do it.
SOURCE: KLH SUBWOOFER - RECEIVER-SURROUND SOUND -5 SPEAKER HOOK UP INSTRUCTIONS
Had the same problem with KLH E-10D Preamped Subwoofer. Afte brief research, I found the problem was with my Pioneer VSX-D509S reciever settings, not the subwoofer. If you have the same reciever, you can go to the pioneer website to download specific model owner's manuals.
http://www.pioneerelectronics.com/PUSA/Support/HomeEntertainment/ch.AV-Receivers.Archived?vgnextfmt=Archived
Select your Pioneer reciever model and it will give you an option to download the pdf manual. Hope this helps.
SOURCE: Yamaha RX-V365 unable to receive 5.1 audio from TV with HDMI
If you're expecting multichannel sound FROM THE TV instead of from the source you're watching, it's not gonna happen. TV's are notoriously poor sound sources. This one is no different.
Multichannel TV-related audio is best found at its source - cable / sat / dvd / bd....
I run video-related audio from my video sources directly to my TV and their audio directly to my receiver. Specialization yields best results.
I'd recommend skipping the Receiver for video, too, as it adds a lot of opportunity for HDMI-related incompatibilities and sound syncing problems. The more interconnects in the path, the more distorted it will become and the more opportunities for problems. Plus you can bypass the receiver and listen to lo-fi programming like news and weather through the TV's speakers if you like. Save a buck on electricity.
Just curious, which HDMI on the receiver is connected to your TV? Input or Output?
This note is on Page 11 of the manual:
Audio signals input at the HDMI jack are not output from any speaker terminals but output from the connected video monitor. To enjoy the sound from speakers connected to this unit,
-- make an analog or digital connection besides the HDMI connection (see page 13).
-- mute the volume on the connected video monitor
"Check SP cable." -- The unit is perceiving a short circuit. Are your speaker impedances sufficiently high? Disconnect the Front Right speaker and try raising the volume again. The speaker may be blown or the cable shorting.
