Question about NordicTrack Exercise & Fitness
Nordictrack t7.0 belt wont move when powered on. ill run on it to get it started and it usually works and then works properly through whole workout.anything i can do?
    Problem Solver:
  • 23 Answers
There are a number of possibilities which a technician may have to help with and fix your machine. Here is a possible explanation: Most electric motors include a capacitor in their circuit (likely these days to be a component on a circuit board, a place where I give up quickly due to the complexity). The capacitor acts like a "primer" that gives the motor a little "kick" to get it moving. This capacitor is automatically switched out of the circuit when the motor comes up to speed. When a capacitor is non-existent or fails in the circuit, the motor will still function normally after you give it some "manual encouragement" as you described by making the belt move with your feet. On older motors, I have seen capacitors sitting in a clamp directly on the motor body. This would be an easier fix than messing with a circuit board to find the bad component.
Posted on Feb 04, 2019
SOURCE:
  • 40 Answers
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
Posted on Nov 01, 2009
  • 1456 Answers
SOURCE: my ex100 logitech mouse isn't working properly
Hi there
Your mouse buttons are stuck and can no longer hold firmly.
The best solution is to get a new mouse because repairing the mouse might cost almost the same price as buying a new one.
have a great day!
Posted on Jul 04, 2010
  • 218 Answers
SOURCE: my NordicTrack EXP2000i Will not
controller is bad
Posted on Aug 13, 2010
  • 218 Answers
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
  • 42 Answers
SOURCE: NordicTrack T5.3 belt stopped working. It's only 1
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Posted on Nov 21, 2010
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
Belt not working
I believe your talking about the Controller, not a computer board. This device may turn on, however; the instructions and sequence of activity will not work. Many reasons for this to happen; and usually the problem is traced back to a power surge. Major components and equipment need to be plugged into a UPS (Uninhabitable Power Supply) with special protection to avoid damage to vital electronics. If plugged into the wall (directly) there are no protection devices and current can pass through a device and damage the controll unit.
Mar 25, 2014 | Nordic Track NordicTrack C2150 Treadmill
My NordicTrack T5zi Walking Belt Treadmill won't
Very likely your console went out. I usually check for voltage running to the console (the wires in the back) and if it has juice but will not come on, I replace the console. As far as "why", usually it is power fluctuations, it can be as simple as turning on a high-amperage piece of equipment, or running too many electronics on the same circuit. I see consoles go out from low voltage more often than high voltage.
Nordictrack is an Icon product, you can download the product manual and parts diagrams at iconservice.com.
Feb 02, 2013 | Exercise & Fitness
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
Belt doesnt work when I hit the start button
Sounds like the motor control board. Everything will work properly but belt want move. Clock will even start to count down.
Nov 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Oct 29, 2009 | Nordic Track NordicTrack Treadmill, A2550
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
165 people viewed this question
Top NordicTrack Exercise & Fitness Experts
Craig Butler
Craig Butler
Ross Metcalfe
Ross Metcalfe
Kardoc
Are you a NordicTrack Exercise and Fitnes Expert? Answer questions, earn points and help others
