Found this ... hope it helps ...
" 87025760 Comet AXD3020 replacement pump 2000 psi @3.0 gpm, 3/4" shaft. Fits most 7hp and below engines with horizontal mountings."
Otherwise maybe these guys can advise.. Good Luck! https://www.rjbowers.com/xcart/Comet-AXD3020-Replacement-Pump-87025760.html
SOURCE: what type of oil goes in a comet axd 3020 pressure
You should use what the pump manufacturer recommends. Typically a 30wt non-detergent (non foaming) oil. Do not over fill. If there is a sight glass half way is normal. Or if it has a dip stick follow the mark there.
Here is a great link for pressure washer parts and info
This link goes right to oil page:
http://pressure-washer-parts.com/shopdisplayproducts.asp?Search=Yes
