SOURCE: Cannot connect using LG internet cube software
how can we install the modem driver correctly please help.. confuuuuuuused
The_Wise23 - delete and try reinstalling your lg usb modem if that does not work call your provider and see if they can assist you more.
chinesebox - the best thing to do is uninstall all lg software and then reinstall it.
for all other users un-install then reinstall
SOURCE: Need to Change WEP Data Encrytion to WPA in Wireless Network Connection Properties
Hiya, first thing you should check is that your wireless card/usb on your laptop actually supports WPA. I changed to WPA and 3 out of 5 of my laptops could not log on. Took me an age to find out what was wrong. Try changing back to WEP on both units. If they can both log on then see if you can try to borrow a wireless card that you know supports WPA, change back to WPA settings and see if new card works. Don't even assume that new cards/usb's are all WPA compatible. Friends was bought in Nov and isn't able to run WPA.
SOURCE: my network settings don't match wireless router.
First Option :
Connect your computer directly thru Router LAN Port. now
If your Computer is configured thru Static IP address then change it get IP address thru DHCP. and Re start the computer. So it will get IP address from Router and you will be able to access Router Admin thru browser.
Second Option
You will have to reset router to factory defaults. To do that ; There will be Tiny Hole or Switch on Router Back side or front side.
Using strait Paper Clip wire ; Put in that wire in that hole and give very light pressure for 5 to 10 second. Make sure that router is Power ON.
So your router will be resetted to Factory default. Now reconfigure it
SOURCE: i have internet but can't
dear friend,
APN means access point name....can you tell me your service provider so that i can easily give you an APN as it differs from service to service...
don't forget to vote me
enjoy & Cheers
