Question about Precor Exercise & Fitness
Precor 956i will not come on - Precor Exercise & Fitness
  • Precor Master
  • 1,642 Answers
2 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: Hello, I need a circuit board for Precor 956i, international model (230v).
Dear Sir:
You can go www.fitnessrepairparts.com + www.treadmilldoctor.com +www.treadmillpartszone.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Mar 10, 2012
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Feb 11, 2016 | Precor 956i Experience Series Treadmill...
Precor experience
Even in a commercial environment, the batteries eventually go dead. Will they go dead faster because of lack of use? Depends on what exactly 'occasionally' means in your case. If it means rarely, then get an adapter.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Aug 22, 2014 | Precor 956i Experience Remanufactured
Error code 16 coming up on my treadmill 956i
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Precor 956i
Sometimes a bad MCB will cause a vibration at certain low speeds. If you have another unit, swap MCBs to verify.
Feb 07, 2014 | Precor C956i Treadmills with HR /...
Dear Sir:
ernesto cuadra
Mar 08, 2012 | Exercise & Fitness
Belts are slipping,
hi,
your treadmill's belt is loose. You have to tight the belt from the both side.
all the treadmills follow the same procedure for tightening the waking belt. Watch the following video for the same.
ok
Mar 16, 2011 | Precor 956i Experience Series Treadmill...
We have a 2 new 956i treadmills why don't they run with a GFCI or will they?
Most treadmills are designed to use the ground to disperse extra static energy - the ground on the GFCI is used to detect fluctuations in the current flow from the hot to the neutral side. The difference in current flow can be as small as 5 milliamps. When the ground pin on the GFCI detects this fluctuation, the ground will open the circuit. This is why it is not recommended to plug a treadmill into a GFCI.
Nov 17, 2010 | Precor 956i Experience Series Treadmill...
On my Precor 956 i the Stop Key prompt appears
There is a micro switch under the red "Stop" button. The switch is stuck and needs to be replaced.
Oct 24, 2010 | Precor 956i Experience Series Treadmill...
Exercise & Fitness Logo
156 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
