SOURCE: remove front wiper arms. Lift arm, slide out
Just pry them off. Make sure the tab is out the whole way. Sometimes they can be tough to get off. Spray with wd40 it should aid in getting it loose. You could even tap it a few times with a rubber mallet or a light hammer, just be careful. Good luck if this helps let me know.
SOURCE: How do I release the tailgate off the truck? I
there is a certain ANGLE it comes off, not all the way down or up....
SOURCE: Town and country 2005 key fob will not unlock front doors. It will however open the tailgate??
do you have a second fob try it battery may be low may need reprogramed or replaced check with your dealer
