SOURCE: Sputters & quits at proper RPM for engaging trans or mowing deck
If the choke has an adjustment point, then adjust the choke to a good overall working powerband. If it still doesn't act correctly, look for vacuum leaks. If it is an option, you may want to install a manually operated choke lever.
SOURCE: Yamaha outboard motor manual
You got it :
http://www.yamaha-motor.com/outboard/service/viewmanuals/outboard_manuals.aspx
here !
SOURCE: tecumseh hm80 snow blower motor linkage
below is a web site for you to check out the parts at. Hopefully this helps you out. If not, let me know and I will try to get you a better diagram. thanks.
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-HM80-155315N-PARTS-LIST.pdf
SOURCE: Carb and throttle linkage on a Tecumsen LEV120 361015A
You want the spring to hold tension against the governor.
SOURCE: Poulan Lawntractor 13.5HP throttle linkage missing
The easiest thing for you to do is look at another mower that has a single cylinder Briggs at how the linkage is set up. They will all be the same linkage from 12 hp- 20 hp.
