Have you tried DVD lens cleaner, more than one DVD, Menu down scroll down to Setup scroll down to reset?
Hitachi L26D103 Operating Manual Quick Guide For Menu Operation
SOURCE: recorded dvds wont play in other dvd players
You have to finalize the disc. if the disc goes to the end it will finalize the disc automatically. If there is some part of the disc not used you have to do it yourself. IN DVD MODE PRESS SETUP, THEN DISC EDIT, THEN FINALIZE. FINALLY PRESS YES. That should do it.
SOURCE: HO7 displayed on machine and won't play dvd
email me your email address and i will show pic's how to my email address is [email protected] plzzz email me i will help but for now i will help step for step.
1)open your driver and pull out the plug.
2)nou the driver is open pull of the cover infront of the dvd player.
3)nou screw open your dvd player and take of the cover.
4)screw of the driver take it out.
5)nou clip of the lazzer and take it out gently.
The top resen of the HO7 is problem is it movement is dry use selicone spray to spray it there will be a thing that makes it spin but for screen shots plzzzz email me.PLZZZ RATE ME FOR NOU BECOUSE THIS PROBLEM IS NO MORE IT IS SOLVE FOR SHORE..
SOURCE: "Wrong disc" memorex dvd player error
Sounds like a build up of dust on the lens.
2 options -
Either buy a DVD lens cleaner
Note DVD LENS cleaner, NOT DVD Cleaner the latter is for the discs, not the player
or second option is to remove lid from your player (usually 5 or 6 screws) and gently swab the lens with a cotton bud or similar soft lint free product. Try not to push too hard on the lens or you may damage the mechanism.
The lens is really obvious as it faces upwards and looks like a small round clear glass bead.
Make sure its unplugged too!
SOURCE: DVD Player stopped working... will not LOAD/PLAY dvds
DVDs will not load / play... problem just started... TV approx 14 months old. Recently DVD was working and the TV just "SHUTOFF"?
