THE CONTROL PANEL IS LOCKED.IN THE MANUAL IT SAYS TO OPEN DOOR AND PRESS #3 CONTROL UNLOCK BUT NOTHING HAPPENS ANY HELP WOULD BE GREATLYAPPRIECIATED THANK YOU
Unplug the range for about 3 hours then plug in and listen for lock mech. then gently pull the door open. Then if your oven doesn't work replace the oven sensor. These tend to go out after a few years when people run the self clean.
I understand you are struggling with the lock feature on your Electrolux duel fuel range, model EW30DS65GS. In order to cancel the Control Lock feature, press Control Lock and hold for 3 seconds. The control will unlock the oven door and resume normal operation.
This door lock feature is activated by pressing Control Lock and holding for 3 seconds. The Door Lock indicator light will flash for 20 seconds until the door has finished locking. Do not attempt to open the door while Door Lock is flashing, this may result in the door locking open.
Hi robertkbrown...you may want to try to following steps.....good luck my friend...chris
If ?LOC DOOR? is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
3. While you hold the door jamb switch in this position, complete the following steps.
4. Press the Clean pad, wait 10 seconds.
5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
6. Wait 10 seconds for the display to clear.
7. The door should unlock and there should not be a need for service.
Manual Switch
1. Press the Clean pad.
2. Close the door.
3. Slide the latch to lock the door.
4. Hit the cancel button immediately.
5. Unlock the door.
Manually Unlocking the Door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the
bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is
heard.
6. The door may be opened.
The oven thinks the door lock will not unlock after the self clean operation. This could be:
1. Door lock motor problem - did the door unlock after cleaning? 2. Unlatch-sensor switch on the door lock mechanism - switch or wiring may be bad, or switch out of alignment. Try opening and closing the door a few times to see if it clears (if it's not locked). 3. Control board not sending the proper unlock signal to the lock motor. We repair control boards at www.fixyourboard.com.
Pull the plug, wait 5 minutes and plug it back in. Don't touch anything! First check to make sure the door closes. If it does you are ready to set the self cleaning mode.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1. Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Remove the plug from the socket for a few minutes. Then plug it back. Does the clock control blicking? look at the pictures on the control as a whole.
Do you see anything like a table clock? press it once, then press the numeric pad or up and down arrow button depending on the model you have. press enter or start if set correctly.
turn power off. take back off range. manually unlock door. it sounds like your control panel is shot.after you have it unlocked turn power on try your oven
