SOURCE: Garmin Registration Code lost
i lost my registration code for the Garmin StreetPilot c330. How can i get it?
SOURCE: Lost Memory and Map Data
I just spoke with Garmin and they walked me through correcting the problem - very helpful. It is a matter of resetting the unit. Turn unit off, then press a finger tightly against the bottom right hand corner of screen, holding it while turning unit on. When screen comes up, let go of power button but still pressing bottom right hand corner of screen, answer question regarding deleting defaults. It is tricky and may have to be done a couple times. Then you will answer questions regarding time zones, etc. When finished with this, turn unit off and go outside in order for the unit to re-aquire satellites. When all four bars on upper right hand corner turn green, you're back in business - or at least it worked for me. Hopefully this will help, but you may want to call Garmin as they are really helpful and can explain it better than I can. Good luck!
SOURCE: Nortech Navigator e-gps010 map updates
You can contact Ferro Works and they will send you a new CD with maps on it. They were not very clear on how updated the Version is. I called them and had a commitment of a new CD to be sent to me within fifteen minutes of dialing.
Here is the Info
619 Slack Street
Steubenville, OH 43952 USA
Tel:866-578-0101
E-mail:[email protected]
SOURCE: is map navigator inbuilt in nokia 7610 supernova,
No it has not inbuilt map. you have to buy the map depend on your country and area then you can use it.
Regards.
