Posted on Jun 25, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I empty and reset the waste toner box WT-220CL in a Brother Printer MFC-9340CDW
Jessica Michael
Level 3:
Master:
  • Brother Master 459 Answers
  • Posted on Nov 03, 2018
Jessica Michael
Brother Master
Level 3:
Master:
Answers
459
Questions
Helped
305170
Points
1452
1) Turn Off the power switch. Open the top cover completely by raising the handle. Remove the drum and the toner cartridge assemblies.
2) Lift the belt unit and then pull it out. Take the orange packing material out and discard it. Hold the green handle that is present in the waste toner box and remove it from the Brother MFC-9340CDW printer.
3) Unwrap the new waste toner box. Insert the belt unit back to the printer. Slide the toner cartridge assembly and the drum unit into the device. Make sure that the color on the toner cartridge and the color label is the same.
4) Repeat the above steps to install all the toner cartridges and drum unit. Close the top cover and turn On the printer.
For more printer related support visit our website @ https://goo.gl/4bc47n
Kevin Gumpp
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Oct 10, 2018
Kevin Gumpp
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
24707
Points
25
On most color machines emptying the waste toner cartridge isn't an issue because the auger system dumps it into the waste toner. The brother machines before this a different way and have a cleaning blade in them. This blade wears out over time and needs to be replaced. Those waste toners last forever in that machine so your better off just replacing it. Other wise you probably are going to make a huge mess just to have problems once you get it back together.
5 Related Answers
Anonymous
  • 624 Answers
  • Posted on Feb 17, 2007
SOURCE: Ricoh CL3000 Laser Replace Waste toner
Couple of things to try: - If you just emptied the waste cartridge then you have to take the bottle back out and clean the insides as well. The sensor sees the toner on the walls and still thinks it?s full. FYI as typical the manufacturer recommends replacing the bottle with a brand new one. - If not that then you may have toner covering the optical sensor. Try blowing the area where the waste bottle attaches to the printer with canned air. Let us know if you have any other questions and please don?t forget to rate this post.
Anonymous
  • 279 Answers
  • Posted on Jan 14, 2008
SOURCE: waste toner tank
A few things can cause this.
The way the printer determines whether the waste tank is full is via 2 optical sensors, one on either side of the tank. You'll see a rounded bulge on one end of the tank - the sensors are on either side of that, when the tank is installed. Under normal operation, light passes through that and the printer reads it as meaning the tank is not full, until the tank fills far enough to fill that bulge, and thus block light and give a tank full reading.
If the tank gets too dirty, not enough light passes through and it gives false tank full readings. So the first thing to try is cleaning the tank with soap and water. Make sure that area is as clear as possible.
If that doesn't work, it has also been reported that the sensors themselves are unreliable. I am told Samsung will replace the sensor for free if it's been less than 3 years. If you call them, insist that it is the sensor that is the problem, or they will try to get you to replace the waste bin, at your expense, first: 1-800-726-7864.
Alternatively, you can remove the sensor from one side, and reattach it to the other side - putting the two sensors in contact so that they always read an empty waste tank. Do this at your own risk, however, as you will have to check the tank regularly and make sure it doesn't overflow. Doing this bypasses the sensor, so there is no longer any warning if your tank is overflowing.
Hope some of that helps you.
-Dyllan
Anonymous
  • Posted on Mar 16, 2008
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Anonymous
  • 284 Answers
  • Posted on Nov 03, 2008
SOURCE: "replace waste toner box" error
sorry there is no quick solution you need a tech to go into service mode and reset the counter
Anonymous
  • 19 Answers
  • Posted on Oct 11, 2009
SOURCE: What is a waste toner box. what does it do and. BEWARE THIS NUMBER 1-800-975-0148 IS SPAM HERE
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
2answers
Brother mfc-9340cdw keep getting error message install waste toner box.
According to the brother support web site the printer should detect the new waste toner box.
However if it does not detect it you may need to clean the contacts
see
https://support.brother.ca/app/answers/detail/a_id/134713/~/how-do-i-clear-the-message-replace-wt-box%3F
for more details explanation of issue
How do I clear the "no waste toner box" message after resetting the drum on my Brother MFC-9440CN (the waste toner box is installed).
The message 'No Waste toner box' indicates the belt unit is not installed properly. To verify the belt unit is installed properly, follow the steps on this link:
https://help.brother-usa.com/app/answers/detail/a_id/76056/~/how-do-i-clear-the-message-no-waste-toner%3F
If the problem continues, the printer may need service. The printer has a one year limited on-site warranty. If the printer is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the printer is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
How do I clear the "Replace Waste Toner Box" Message from the display - new WT220CL installed in a Brother HL3140CW?
To clear the message 'Replace WT Box' from the LCD display, power off the printer using the power switch on the right side of the printer. Wait 5 seconds and then power the printer back on. If the printer continues to display the message 'Replace WT box', the waste toner box is full and needs to be replaced.
Waste toner box in mfc9840cdw is full
The waste is captured more for easy, clean and safe disposal. As far as operation ogre the printer you could empty the waste and RE use the bottle.
9helpful
3answers
How do I reset the waste toner box in my MFC-9840 Brother printer? (without purchasing a new one)
1. 2. -> unscrew
shake to empty
http://s14.directupload.net/images/130409/awjs9m88.jpg
Norman Weimar
Norman Weimar
k24674
