Dishwashers Logo
jose velez Posted on Jun 25, 2018
Jackson dishwasher is over heating - Jackson Dishwashers
I am a new tenant in a building with a round Jackson dishwasher. I'm trying to follow the instructions. I can see two strainers, one round, and the other cylindrical. I've looked at the manual
You have neglected to include the model number which you must have if you have the manual. Jackson produced a number of models. That said, here is a site that may help you because it shows where parts go in a schematic:
Wash Rinse Assembly
Contact Jackson WWS
When I turn on my Jackson Delta 5 it says that it is heating water, and that is all it will do. It will set like that until I disconnect the thermostat wire and plug it back in. Then it will continue the...
THIS could be your huckleberry! It is item 3 of suspects...
Also note ITEM 7, "heater delay relay"?
Disconnecting and reconnecting MAY be resetting that relay!?
ALSO BE VERY AWARE OF THIS:
BEFORE the heater element can be energized, the rinse
booster heater MUST be initially filled with water. Damage to
the heater element will occur if the element is not submerged
in water!
Here's your thermostat:
Jackson 5930-003-13-65 THERMOSTAT,
120-170 DEGREE "WAS"
thermo-xpxypaj2co3qxlf13c0q1l2g-5-0.jpg Find it here:
Jackson 5930 003 13 65 THERMOSTAT 120 170 DEGREE WAS
$137.11 plus shipping
OR SAVE SOME LOOT AND GO HERE:
eBay: Jackson thermostat 5930-003-06-48 175-195F
Item location: Camano Island, Washington, United States
eBay:
122938835291
$129.50 INCLUDING SHIPPING!
Get your MANUAL here:
http://www.jacksonwws.com/wp-content/uploads/2016/08/Delta-5E-manual.pdf
text: 'TEMP WASH AND RINSE: 120 degrees'
>>> 140 degrees recommended for BOTH (see page 3). <<<
TROUBLESHOOTING on Page 16 and 17!
"Wash temperature not at required reading."
1. Check that white/blue wires are connected.
2. Defective thermometer.
3. Defective thermostat.
4. Rinse heater defective.
5. Defective heater contactor (R2).
6. Incoming inlet water temperature below required minimum. 7. Defective heater delay relay (R4)
See ANOTHER GREAT troubleshooting chart here!
http://kitchen.manualsonline.com/manuals/mfg/jackson/delta_5_d.html?p=21
$50 please... JUST KIDDING
Anthony
Temperature not getting to 160o
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Dishwasher keep tripping power from circuit panel?
That could be either the motor or the heating element...
You will need to check it out with an Ohm meter to tell for sure what the exact cause is...
heatman101
Jackson 24-B dishwasher detergent/rinse hookups where are they?
they are located under the front panel of the machine they should be lablet , usually they are by the timer cam
2helpful
Machine fills with water overnight .jp24b jackson dishwasher
Your water inlet valve is likely leaking by. Could be something is stuck inside or possibly the valve is worn out. The Jackson part # is 04810-100-12-18. There may also be a rebuild kit available. You should be able to purchase this from your local repair company.
Top Jackson Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
Bonded Repair
Don A
Don A
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
