Question about Bunn Coffee Makers & Espresso Machines
Slushie machine leaks from back seal. got new seals but cant seem to solve this problem - what am I doing wrong?
It is a Bunn with 2 cylnders- runs and cools great. But leak is a steady slow flow from rear.
    Habit-Forming:
    New Friend:
  • 76 Answers
Rear wall may have a crack in it? Examine it closely.
Posted on Apr 27, 2019
SOURCE:
pal03246
  • 726 Answers
SOURCE: Rear end seal leak
You must be refering to the side seals. common problem. the actual problem with those rear ends is the air breather, which cloggs up and that's when your seals blow out, because the pressure in the rear end has nowhere to go and so your seals get blown out. I just did a set on Monday. Anywho, you will need some specialty tools for this. You will need to remove both rear brake assemblys (rotors, calipers). Than look on the other side of the backing plate, there you will see 4 big nuts that hold the backing plate on the axle tube (rear end). Remove those 4 nuts and that's where specialty tools become usefull. You will need a slide hammer. You need to attach the slide hammer onto the axle right by the studs. Use factory whel nuts to attach. Remove axle out of the housing with few good slides of the slide hammer. Once the axle is out, you need to remove the snapp ring, then cut the colar off and remove colar, then remove the old bearing and thats where the seal is. Big help doing this job is a pneumatic air hammer, which helps you remove the stuff off the axle shaft and the slide hammer to remove the axles out. You will need 2 seals, 2 bearings and 2 collars. You may also need the plates with the studs, which had the big nuts, that you removed in first steps of this repair. Kind of a job for someone that has been working on cars and has the tools to do it. Good luck. Oh ya, change the breather and the fluid in the rear end.
Posted on Oct 22, 2008
LEFTY64
  • 69 Answers
SOURCE: leaking rear axel seal
  1. Remove or disconnect the following:
    Rear wheel Brake caliper and rotor, if equipped Brake drum, if equipped Axle retainer nuts Axle shaft, seal and bearing assembly
  2. Split the bearing retainer with a chisel and remove the retainer ring.
  3. Press the bearing off the axle shaft.
  4. Remove the axle seal and retaining plate.
0900c15280220349.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Rear axle seal and bearing components-2002-05 exc. 2005 Grand Cherokee Hope this helps, please dont forget to rate my solution.
Lefty64
Posted on Apr 09, 2009
  • 304 Answers
SOURCE: Rear Axel Seal Leaking, How do I pull the axel to repair?
You will need to remove the differential rear cover,drain fluid, remove wheel, brake drum, (rotor) . Unbolt center diff. pin, carefully remove (don't loose shims) push axle in remove lock keeper, then slide out axle, replace seal, put some grease on it, slide axle in reverse all to install.
Posted on May 22, 2009
SOURCE: oil leak problem with 1996 toyota camry
I am going to see a mechanic - my trusted mechanic who does not nickel and dime me - to see what this is. I have the same problem and he told me he has never done this job on a Camry and is unsure. Given the miles, he has suggested that maybe it is time to part ways with the car. I am going to ask him if he will put some florescent dye in it and let me drive it for 50-100 mi and then check to see where the leak is and fix it. Let you know what happens. I have to try, the car is solid.
Posted on Aug 15, 2009
  • 3 Answers
SOURCE: REAR AXLE SEAL IS LEAKING. HOW DOES THE AXLE COME OUT
rear axle at leave parking brake wet how to replace seal
Posted on Dec 07, 2009
How do I stop water leak
If you're talking about the model shown in your picture, the leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Oct 03, 2014 | Bunn 10 Cup Home Coffee Brewer
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
Oct 02, 2014 | Bunn Coffee Makers & Espresso Machines
Get maintenance and shaft seal off diplay
hold down the word "gourmet" near the display for 5 seconds and release when the words change. it is a hidden button to get you into the menu. press and release until you get to the "pm" question then press "ice" for yes. keep hitting gourmet until it goes through the menu and the machine restarts. this will appear every 6 months to make sure you check your seals for leaks. if you have product flowing out of the bottom or side vents of the machine, replace the seal between the auger and the drum
Sep 08, 2014 | Bunn Ultra-2 HP High Performance Slushy /...
How to fix a leak on a bunn NHBX coffee maker
Aug 09, 2014 | Bunn NHB Coffee Maker
Oil coming out of back of machine
it isn't oil, it's old, syrupy slushie mix and dust. the only oil in the machine is inside the hermetically sealed (cannot open) compressor. you have a front seal problem. the shaft seal in the front inside the evaporator (steel tube), and the cup-shaped seal between the auger and the evaporator. slush is getting inside the shaft tube and dripping through the inside rear of the machine. replace the seals, lube with a food-safe lube and refill.
Mar 04, 2014 | Bunn Margarita Machine Ultra 2 Slush...
One side of my bunn ultra 2 slushie machine is leaking how do you change a bad seal to stop this problem?
remove the bowls by pushing in black button on the bottom front left of the bowl, pull the bowl up a little, then pull it forward and off. pull the auger off and the seal is opaque, cup shaped, and on the shaft. replace that, lube the edge with food safe lubricant (i.e. superlube), lube the large round bowl seal in the back and put it all back together. you may need a preventive maintenance kit installed as well, but that's a bit more involved
Sep 28, 2011 | Bunn Margarita Machine Ultra 2 Slush...
My Bunn coffeemaker is leaking water after it stops brewing and the coffee doesn't seem to get as hot as it once did. It also only gives back 4 cups for a 6 cup brew.
if you unscrew the top there's a rubber seal in there that you might have to replace that causes the leaks. also clean your coffee maker regularly with vinegar.
my husband had to replace the seal in ours 4 times but after owning the same Bunn for 20 yrs it was time for a new one
Jan 18, 2011 | Bunn 10 Cup Home Coffee Brewer
Clutch problems .I have to pump my clutch for 15 minutes to get it to shift into gear when car is running. What is the problem
this is due to air in the clutch system, or a low fluid level. bleed some new clutch fluid through. It may be caused by a leaking seal, so check for leaks at the clutch master cylnder and slave cylnder. the master cylnder seal sometimes leaks down the firewall inside the car. Replacement cylnders ar an easier option than replacing just the seals
Apr 20, 2010 | 1996 Nissan Maxima
Bunn Ultra slushy machine has black goo leaking out of machine. Can't find a service professional to look at it.
black goo .. actualy syrop is leaking rom the bin and collecting in the machine.you nead to stip the machine and steam clean it . replase the seals for the auger and bin. and lubricate them with food grade lube during reasembly.. your not alone. hopefully there is no damage at the auger housings.
hope this helped
Oct 06, 2008 | Heating & Cooling
Coffee Makers & Espresso Machines Logo
219 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
