The wires connector at the module, distributor, and coil do look corrosion on a 1975 Ford F350. i think it might be electrical grease done dried out and old.
SOURCE: 1984 Ford E-150 Econoline van It has no spark
Are plugs and wires good? Did you check distributor? Firing order correct-timing set right? Maybe some of the new parts are faulty? Are grounds all secure and are fuses good?
SOURCE: 1995 Ford F350 5spd. distributor cap wiring diagram/layout!!!
1) #1-4 pass side front to rear #5-8 drivers side front to rear
2) 1-3-7-2-6-5-4-8
3)#1 is usually marked on cap wires go ccw
4) TDC #1 cyl you must remove the shorting plug before timing
it is located by the dist plug or the ignition module small gray plug
SOURCE: 1999 Z24 runs rough when warm
Buy a couple bottles of gas line antifreeze.... the coil would have been my first suggestion... but it sounds like you have water in your gas as well.... gas line antifreeze is alcohol (not the kind you drink) it sucks up water tho.
Robert
SOURCE: No spark?
Hi, common thing with the mazda was the coil or the ignition amplifier going faulty, both of which are located within the distributor, the coil ususally gives the symptoms you describe, a weak spark. The coil is the most common failure aswell for your vehicle i would recommend a new one, also make sure distributor is spinning as it could just be a case of a broken timing belt.
Good luck Davelee
SOURCE: Car just stopped running. Lost power suddenly.
Find an inductive pickup indicator for spark. Place on distributor cap to see if spark is at coil internal tower. If no spark at internal tower, look at ignition module or pickup coil. Ignition modules are prone to failure on 626's. But if you have spark at tower but not at the wire end, then your rotor is gone.
Buy a tube of dielectric grease to squeeze into the connections after cleaning .
