Question about Camping, Backpacking & Hiking
Install battery in evatac flashlight - Camping, Backpacking & Hiking
    Top Expert:
  • 1,116 Answers
Posted on Mar 11, 2019
SOURCE:
Utilitech flashlight. How can I replace battery?
  • Open battery compartment
  • Remove old battery (or batteries?)
  • Install new battery (or batteries)
  • Close battery compartment
  • Check operation
Mar 08, 2015 | Camping, Backpacking & Hiking
Tip
Prevent battery damage to flashlight
Any flashlight that uses non-rechargeable batteries, IE... AAA, AA, C, or D batteries. If it is not used on a regular basis and sits for a long time with the batteries still in it, the batteries will leak and damage the flashlight. It is recommended that if the flashlight is not going to be used for long periods of time, that you remove the batteries to avoid leakage into the flashlight. This also is recommended for anything that uses this type of battery. These types of batteries are known leakers.
on Feb 20, 2011 | Camping, Backpacking & Hiking
Tip
How to replace the lamp in a Mini Maglite
The Mini Maglite is a durable, compact flashlight. If your Mini Maglite stopped working, check or replace its two AA batteries first, and if that doesn't fix it, you'll probably need to replace the lamp. You can order replacement lamps in packs of two online, or you may be able to find them locally in a hardware store.
To replace the lamp in a Mini Maglite:
1. Unscrew the bottom of the flashlight. (Hold the flashlight with the head facing down so that the batteries don't fall out.)
2. Remove the batteries.
3. Unscrew the flashlight head from the barrel.
4. The lamp is mounted into the flashlight on two prongs; gently pull up on the lamp to remove it.
5. Install the new lamp by lining the prongs up with the two holes and slowly inserting it fully.
6. Screw the flashlight head back on.
7. Reinsert the batteries.
8. Screw the base back on.
When you've finished, turn the flashlight on (by turning the lens cover or the head counter-clockwise) to verify that the new lamp works. If the light doesn't come on, take the flashlight apart again and check to make sure the lamp is installed correctly and fully. Since the lamps come in packs of two, if you can't get the first lamp to work, try the second lamp in the pack. If that lamp doesn't work either, check your batteries and make sure the lens cover and head are both screwed on all the way.
on Jan 12, 2011 | Kitchen Appliances - Others
Put batteries in a highland series 150
I'm not familiar with this particular torch but similar torches use an adaptor such as one depicted below to enable AAA batteries to be used where the primary battery is either a 18650 battery or two CR123 batteries in series. I hope this helps.
Sep 21, 2014 | LifeGear Life Gear Highland Series 150...
How do you install 6V battery into Dorcy luminator
I was just having the same problem - I didn't realize that I had to take the black caps off the two springs at one end of the battery! Once I pulled those off, and put the battery in with the springs facing up, I was able to screw the top of the flashlight back on, and it worked. I hope this helps.
Oct 28, 2012 | Dorcy International p6V Floating Luminator...
How do i install batteries on stanley 95-112 tripod flashlight
I just found it! The batteries go into the tripod legs! genius
Dec 30, 2010 | Stanley 3in1 Tripod LED Flashlight 95155
Got new Energizer Hard Case Flashlight model IN421
Well much to our surprise the easy way is the best way. There are no instruction on the package nor on Energizer website but after googling we found reviews of the flashlight and how long it took others to find out how to put the batteries in. Although the base is square...it DOES turn and voila....comes off to insert batteries.
Dec 26, 2009 | Energizer Camping, Backpacking & Hiking
Mini Maglite not working
You could have dirty contacts if the batteries were in for a long time and you never used it. The contacts are: (1) the tip of the spring and (2) where the positive end of the battery touches way inside the flashlight. You can try and clean them with alcohol. If you think it might be the bulb, try the spare. There is a spare bulb under the spring you see at the base of the flashlight when you install the batteries, you have to pull the spring out and then snap it back in after you get the bulb out. And yes, positive end goes in first in the Maglite. Hope this helps.
Jan 07, 2009 | MagLite Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
4,055 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
ray gallant
Kardoc
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
