It fills with water starts but then stops. you can wait for an hour but no movement - when turning the knob on in its cycle, it does spin and pumps water out. But it refuses to agitate We have replaced the timer with a brand new original timer no improvement the same happens What do you think the problem could be?
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
SOURCE: GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
I have a GE MODEL WWSe5240G0WW top loader washer that has seen very little use. My problem is that the unit will not agitate or spin,every thing else seems to work ok. I did remove the top lid switch and jumped the to wires (Yellow/Red and Orange) still did not make any difference. Any in for would be great.
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: washing machine fills, but will not agitate, drain or spin
Coupling broken which joins the motor to the gear box. Look and see or listen if the motor is running then if nothing else is working coupling is broke, easy to replace.
