You can try this and see if it works for you:
Connect to Wi-Fi networks
Some of this information applies only to devices running Android 5.0 and higher. If your device is running 4.4 or lower, the Menu icon looks like this . If your device is running 4.3 or lower, the Settings icon looks like this .
You can connect to Wi-Fi networks with your device, as well as add networks you use often or remove networks you don't use any longer. You can also change the settings for saved Wi-Fi networks on your device.
Keep in mind that your device will remember networks you connect to, along with security details, and connect automatically when in range.
Turn on Wi-Fi and connect to a network
Once you've connected to a network, it will show up in your Saved networks list. If you have trouble connecting to Wi-Fi, try the following steps:
Time to look up customer service on the internet and use your factory warranty.
Your power cord may not be putting out enough current. Check and make sure it is the right adaptor for your tablet
SOURCE: Bought a ematic 7" HD quad core tablet screen crack bought on 12-24-2015 is it still under warranty
These companies do not make returns for cheap tablets easy ,lessons learned .
