Bluetooth on my Toshiba Satellite P875-S7200 will not pair with my Bluetooth Speakers what can i do since it is the Bluetooth mode on the computer that will not connect.
So what makes you think the laptop has BT?
its and option on all PC made, when new (check this first)
is this the only BT device you own? do tell.
and can be added to any PC on earth with a BT USB dongle stick.
for like $4
what is the distance to the speakers (BT uses radio signals weak)
10ft 50 ft (10 meters) what? distance matters on all transmitters regardless if BT, wifi, wlan, or 3g/4g/. etc...
BT comes in 2 power settings, some devices do not use high power mode. (on speakers this would make for best)
does the speakers pair with any other PC? with BT?
the speakers if not junk has RTM manual. and read the page on
how to reset pairing.
BT loves to memorize your favorite devices, so if problems happen.
learn how to reset that memory , call reset pairing history.
SOURCE: Computer keeps rebooting into safe mode
Try going to system tools, and select system restore .. If that does not work ,May be virus, may have full restore with formating the hard drive
SOURCE: pairing my bluetoth to my blackberry curve phone
When it is turned off, hold the main button in for 4 seconds until the light flashes red, the release. It should flash red and blue. This means it is in pairing mode.
SOURCE: pairing mode for headset with PS3
On your PS3 XMB menu. Go to settings. Scroll down to accesories. Then click on manage bluetooth devices. There you will find the autodetect for the bluetooth headset. While the bluetooth headset is off, press and hold th on button until the LED stays on. The quickly use the PS3 to detect the blue tooth. It will ask for a pin to pair the units up. The pin is four zero's.
SOURCE: Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
Any questions email: [email protected] Subject: omnitech bluetooth
