SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
SOURCE: Kenmore front load washer won't drain
Remove the bottom panel under the door to access the drain pump. Make sure the washer is unplugged before servicing the pump. The pump will be located under the wash tub in the front of the washer. There should be a small access cover that can be unscrewed to access the inside of the pump. If not, remove the inlet hose to access the pump impeller. HINT: Pull the drain hose from the standpipe and use a shop vac to pull a vacuum on the drain line. This will pull any remaining water out of the drain lines and wash tub. This will minimize the amount of water that spills out of the drain pump when you remove the access cover.
It does not take much to damage this small drain pumps. If you clean the pump thoroughly and it still exhibits drain problems, the manufacturer recommends replacing the pump.
If you require additional assistance, let me know before you rate the solution. I hope this helps you.
SOURCE: GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
SOURCE: Water doesn't drain
you could have a bad drain pump.
have you checked the hoses that come from the bottom of the tub to the drain pump for anything that might be stuck in there,also check the hose that comes off the drain pump to the wall and look for an obstruction.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
