Keurig Elite B40 Coffee Maker Logo
Lea J Smith Posted on Jun 22, 2018
Is there an auto off feature on keurig k-elite? It allowed us to set it to come on in the morning, yet not to shut off at night.
Already spent a lot of time on the phone with support. After programming the auto on, it goes to the current time. It does not shut off automatically at night and we would like to know if this is possible. Thank you.
kenjones1999
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Sep 28, 2019
kenjones1999
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
7086
Points
20
The best thing to do it put it on a smart plug, Cost about $15 now-days. you can program the on and off time as well as shut it on and off remotely.
5 Related Answers
A
Anonymous
  • Posted on Jun 06, 2007
SOURCE: Bypassing the parking brake feature
just earth the handbrake cable (light green) on a good earth point.
AGGeek
  • 3 Answers
  • Posted on May 07, 2008
SOURCE: change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 09, 2009
SOURCE: Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Anonymous
  • Posted on May 16, 2009
SOURCE: how to set the auto off??
I had same problem. Could not find manual on-line so I tried different techniques. You can reset the auto-off feature to extend the "On" time up to 3 hours max. You do it by (1) placing the control switch in the "Off" position. (2) Simultaneously push the "Hr" and "Min" buttons. The time display will start flashing the hold time. (3) Push the "Hr" button to cycle through the available hold times, 1 - 2  or 3 hours. When set, turn the selector switch momentarily to any other position to finish the programing.
Anonymous
  • Posted on Feb 08, 2010
SOURCE: I have the Keurig Platinum B70 brewing system. It
This also happened to me. Keurig sent me a replacement and it happened again. I called them this weekend and they said all platinum brewers sold around Christmas and all replacements had a faulty sensor. If you call them they will replace it free with a brewer that doesn't have this problem.
Every morning my Keurig is turned off
The Keurig B70 has an auto off feature that needs to be programmed. You can find the instructions here:
http://www.ehow.com/how_7389997_reset-keurig.html
How do I correct my machine From shutting off my itself?
This is actually a power-saving feature. Keurig actually recommends you let it shut off on its own instead of powering on and off.
2answers
How do I reprogram my platinum Keurig so it does not shut off
With unit powered on, Select Menu button, scroll down, and turn "auto off" to off selection. Cup size is selected after you put K Cup in. The display should flash on a default (1 of 5) cup sizes. You can manually change to the size you want. Alternatively, you can select the Menu button and change the default cup size (same process as stated above).
2helpful
Bought this last night...we spent over 1/2 an hour trying to get it to work properly...finally achieved that...now this morning... 1) I can't get the water to heat up, 2) it keeps turning off, 3) as...
Clearly, your issues are related to issues that can only be corrected at the factory.
Keurig Customer Service: http://www.keurig.com/customer-service
My Keurig Elite B40 will only brew one cup of coffee and then turns itself off. The Auto Off button is not lighted. If I turn it back on the Heating light will not come on and the Keurig will turn off...
If you can also see there are a lot of inquiries about the same or similar problem. We have already investigate the matter and it is a design problem from Keurig and it not any much that you can do,
We have a tip at the link that it explains it some more
http://www.fixya.com/support/r5543433-keuring_coffee_maker_b60_b70
Moreover you can contact the keurig customer service which we here that they are more than happy to help you and in many cases they have replace the machines with no further question, you can try also since you are a customer with rights.
Good luck
Top Keurig Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
