Question about LG Televison & Video
My LG TV is blinking blue and red light. I can't turn the power on.What should I do?
I had the same issue and it turns out it was very dusty. So I blew through the air vents in the rear and this fixed it ????
Posted on Feb 19, 2019
ginko
  • 19396 Answers
SOURCE: toshiba 46H84 tv turned off light blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
  • 5 Answers
SOURCE: red blinking light when tv is turned off
if this is a 37lg30 i have brand new spare parts. the tv was never used it was dropped and the screen was damaged so i just took out the parts out. i was originally looking for some one that had a problem with there tv but a good screen like you but its easier to ship out the boards.
Posted on Jun 06, 2009
dave1645
  • 834 Answers
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
Posted on Nov 06, 2009
hawk127311
  • 350 Answers
SOURCE: the tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Posted on Nov 11, 2009
  • 1039 Answers
SOURCE: power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Posted on Mar 26, 2010
Blinking blue and red lights will not turn on TV is LG
most likely there is a bulged capacitor on the power supply, just have to replace it.
Sep 14, 2016 | LG 42LG50 42 in. LCD HDTV
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
Hello, I have a 42"
Sounds like a backlight is out. If its still under warranty, exchange it. First try unplugging it for two minutes to reset the t.v.
May 15, 2011 | LG 42LG30 42 in. LCD HDTV
Lg 26lg30 light blinks red blue wont turn on. When unpluged light flashes blue for a minute then turns off
Nov 06, 2009 | LG 26LG30 26 in. LCD TV
Televison & Video Logo
391 people viewed this question
Steve Allison
Steve Allison
