1) Look at the top of the old tank.
There will be markings on the tank, probably embossed in the steel cover that show cold - hot.
2) Many tanks have red and blue plastic pieces surrounding the inlet pipes
3) If there is a shut off valve located above tank, it should be on cold water line assuming house was plumbed to code.
4) When we install water heaters in old houses where water heater is removed, we look for shut off valve above tank that tells us which line is cold. If tank is missing and pipes have no shut off valve, we turn on outdoor water supply and see which of the two water heater pipes starts running water first ... because that is cold side.
5) For do-it-yourself water heater information about electric water heaters:
http://waterheatertimer.org/DIY.htmlAdd a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
