Kirby G 2000 the front wheel came off where the peddle adjust height of brush
SOURCE: Carpet Height Adjusment
In addition to the tab that contacts the bottom of the slider, there are 2 protusions on the adjustable wheel plate that move through holes in the housing, but only when the handle is tilted to begin vacuuming. The wheel plate has a spring that forces the tab against the slider. As the handle is moved to the upright position, the protusions move back through the holes, taking the tab away from the slider and the wheel plate locks in its highest position. Therefore, the position of the slider has no effect while the handle is upright and locked. Hope this helps.
SOURCE: Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
SOURCE: Rotating Floor Brush Isin't spinning
It appears that the end of the brush is getting jammed with hairs, treads, and/or dust or the belt may be worn. Try taking the brush out and hold it by the ends and try to turn it. It should turn quite easily if it is working good. If not try taking the ends off and clean them out. Also, make sure the belt is good.
SOURCE: getting the height adjustment to work
is this a piece of **** dirt devil? if so, even when you get it back together the design is so flawed that it will keep breaking the belts, I've already gone through 3 in a week! see my other suggestions to remedy this.
SOURCE: Wheel and lever fell off Kirby ultimate G
the spline shaft is probably worn. you will have to replace the assy.
