C
Clifford Mauck Posted on Jun 21, 2018
I need a owners manual for a KLH KL 2400 - KLH Audio Players & Recorders
5 Related Answers
A
Anonymous
  • Posted on Jul 28, 2008
SOURCE: KLH KL-300i needle
Please contact KLH at 818-767-2843 ext 117
Anonymous
  • 460 Answers
  • Posted on Nov 17, 2009
SOURCE: Model KLH KL-2400 Reciever keeps popping fuses.
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Anonymous
  • Posted on Nov 27, 2010
SOURCE: KLH Digital HA9000 DVD Surround System Owners Manual
I have a manual Contact me at [email protected].
AJIN G
Electro Med Services
  • 6694 Answers
  • Posted on Dec 21, 2011
SOURCE: i need a free owners manual or answers on connections on the back of of klh r5100 channel dolby digital surround receiver
HI,
Check the following link you will get the answer why There is no manual avilable for KLHr5100. Still i dont have the manual for this one.
http://www.epinions.com/review/pr-KLH_R5100_5_1_Dolby_Digital_DTS_Channel_Home_Audio_Receiver/content_554691628676
Ajin
Anonymous
  • 742 Answers
  • Posted on Jan 02, 2012
SOURCE: I NEED AN OWNERS MANUAL FOR KLH R5100 AUDIO VIDEO
here is the user manual for KLH R5100
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Need remote control replacement for a KLH Rec/Amp kl2400
Yes, it might not be the original one but there are
replacements available in your nearest electronic
supply stores.
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
2helpful
Volume out of speakers nill
I bought two of these in "non working" condidition. All it was is this: There are two plug-in's or shunt's whatever you wanna call them that come pre-installed on my units that were up/down and should have been horizontal in block marked "speaker output".
Both unit's work fine now. Came from factory that way!
Try it and let me know at [email protected]
Someone
2answers
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
NOEL
NOEL
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
