SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
SOURCE: I can't seem to unlock my safe Sentry 1250.
Also make sure you are executing the combination in the right steps... For mine (a three-number combo), these are the steps that work:
* turn the knob to the LEFT, pass 0 at least THREE times and stop at the first combo number
* turn the knob to the RIGHT, pass 0 ONCE and stop at the second comb number
* turn the knob to the LEFT and go directly to the third combo number (do not pass 0, do not collect $200)
SOURCE: Sentury Fire Proof Safe 1250
Is there any way to crack the safe by feel, ive seen it done before and have some experience in opening locks with pin tumblers, but not wheel tumblers. i can find the notch in the third wheel at around 10-15 but i dont know where to go from there. I would not be using this information for any illegal use, i just need to open my safe on my own, and soon, thank you.
SOURCE: get the numbers master dial combination lock
Buy the identical lock if possiable and return as defective and they will reset. Otherwise odds or 1 in 999,000 differant combos. This is airport baggage security lock.
Please rate. Thanks
SOURCE: I have a sentry professional quality 6250
I have 6250 safe and forgotten the combo. How do I get in the safe
Yale battery operated safes have a manual override function for which keys are supplied.
