Can't hear on surround speakers. Could a lighting strike have burn out input I was using How do I test and switch to a different input and output?
SOURCE: HDMI Connection to Ooptical Output
Talked with Sharp, it's a issue with hdmi and optical out, best fix for it that I'm currently using is a 3-way toslink splitter, cost a little of nothing and work perfectly, you just turn the dial to the signal you want to play off of. Clicky
SOURCE: Which optical inputs should I use for (1) audio output
Hi, the Optical and Coaxial inputs are assignable to whichever input you need them on. Plug the Optical cables from your DVD and HD cable box into any of the OPTICAL INPUTS (1 and 2 is fine, but write down your connections on paper)
You will then need to go into the setup of the AVR on the screen and assign the OPTICAL connections to the correct inputs (Probably TV/CAB and DVD.
Use the SYSTEM SETUP button on the factory remote, and you should see the on-screen menu appear on your TV. Go to INPUT ASSIGNMENT and choose the input for the DVD and assign OPTICAL 1 or 2...
Reply here if you need more help.
SOURCE: digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Testimonial: "worked like a champ!"
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
