I have updated it over and over with legend of the lawn and it still tells me I need To update it . What the heck?!?
Hello -
I suggest you check one of the discussion forums for Plants vs. Zombies to see if your question has been asked and a solution provided.
Here are links to some PvZ discussion forums:
https://answers.ea.com/t5/Plants-vs-Zombies-Heroes/ct-p/plants-vs-zombies-heroes-en
Registration (free) required
http://plantsvszombies.wikia.com/wiki/Special:Forum
https://www.trueachievements.com/game/Plants-vs-Zombies/forum
Note: If you are using a computer (desktop or laptop) or a tablet for PvZ, if you have not yet done so, before trying to download the update, disable both the anti-virus auto-protect and the firewall. Be sure to enable them both after the download attempt (which I hope will be successful.)
Best wishes.
SOURCE: Trying to upgrade H/D on IBM T43 laptop, get 2010 error on
Error code 2010 is definitely hard drive problem.
Did you get the firmware from the site below?
Link to hardware maintenance manual for reference:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/39t2393.pdf
Here's the fix straight from the maintenance manual:
If in the primary bay the customer is using a non-IBM or non-Lenovo hard disk drive (HDD), or an old generation IBM HDD which is not supported by this system, with the risk in mind, the customer can still use it by pressing ESC. If in the primary drive bay the customer is using a supported IBM/Lenovo HDD with an old firmware, the customer needs to update its firmware to the latest. The latest version is available at http://www.lenovo.com/think/ support
SOURCE: trend micro internet security.the firewall keeps on shutting down
remove TMI through this
http://esupport.trendmicro.com/Pages/How-do-I-remove-old-or-new-versions-of-Trend-Micro-products-in-my-comp.aspx
and then D/L it again
SOURCE: My 1994 Acura Legend keeps running hot. Gauge
When the car is completely cool,check the electric fan(s) for smooth rotation.
Clean/check/change the thermo sensor,contact and wire.
Excavate air pocket in coolant system / check for head gasket leak
This test will kill two birds with one stone.
MAKE SURE THE COOLANT SYSTEM and ENGINE IS COLD!
RAN THIS TEST IN A WELL VENTILATED AREA ONLY!
You will spill some coolant during this air pocket purge test.......BE
KIND TO THE ENVIRONMENT and ANIMAL please clean up after the test!
Put the front end on a pair of ramp or park your car on a VERY STEEP HILL (radiator facing top of the hill) .
Top of the coolant reserve tank
Let it ran for 10-15 minutes.
Monitor for air pockets escaping from coolant reserve tank.
Small amount of bubbles is OK at 1-5 minute mark
After the thermostat open up (after 195 F warm up) at
5-12 minute mark or after high idle you should see less bubbles.
If you do not see any in rush of bubbles then your thermostat may be
partially stuck or rusted badly inside the thermostat hosing.
Give the thermostat host few gentle taps.
If you see larger bubbles surfacing after 15 minutes then should do a
hydrocarbon (HC) dye test to test for potential head gasket leak.
Let engine cold down and top off coolant reserve tank.
Start monitor for coolant lost
A coolant flush is require every 2 years or 24,000 miles.
I recommend the thermostat that has a relief pop-let to reduce the change of burst radiator and coolant hoses.
Make sure you get a new thermostat gasket,black RTV and fresh coolant for the job.
Please post more information by clicking the comment link on the top right corner.
DON'T FORGET to RATE ME if my tip is helpful to you!
SOURCE: Macfreelance software won't update.
Problem with the Summitsoft MAC Freelance for Mac
re update
