SOURCE: my toshiba wont turn on but red light come on an green light flashing no picture or sounds
yes ill got remote link for u here give me one sec
SOURCE: Projector powers on but no picture.
I too am having an issue with the projector's orange light blinking.. blinking ... blinking.... blinking... until I unplug the power. The light starts off blinking green, I hear the projector power try to energize the bulb, however, it gives up after a few tries then starts with the Orange blinking light.......
Assistance would be nice... thanks
SOURCE: power light blinks red - tv will not come on
I bought one of these tv's at a thrift store and it had the same problem, orange light blinking and static sound coming out of the speakers, no video at all.
The problem was the power supply board, this power supply has multiple outputs that feed the circuitry, 12V, 24v, 5V.
There was nine electrolitic capacitors I had to replace to fix it, all of them were bulged they are easy to spot, I measure one of them that was supposed to measure 1000uF but measured only 65uF. you can buy these from digikey for about 50 cents each, they need to be rated at 105 deg c and the profile has to be below the heat sink otherwise they will hit the top of the heat sink, the spacing between the leads has to be 5mm so they fit in the pcb. I replaced 3 1000uF/25v, 3 470uF/16v and 3 1000uF/16v and that fixed the problem, I bought this tv broken for 100 bucks fixed it with 6 bucks.
Good luck, don't perform repair if you are not familiar with dangerous AC voltage inside the TV.
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
