Optics Logo
Frances Sweeney Posted on Jun 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a fractured arm and can’t set up my telescope. Is there a possibility of a home visit to set it up for me
john h
Level 3:
Top Expert:
  • Master 29,494 Answers
  • Posted on Jun 21, 2018
john h
Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7551719
Points
193449
On wrong site this is fixya an online repair forum
Is there a seperate mtr for player arm
Looking at the picture I think it highly unlikely there is another motor. Arms are generally linked to a mechanical cog systems. Of course any of these can loose teeth, fracture, especially if the are abs plastic. That will cause all sorts of problems for the arm movement.
What nerve make a fracture in midhumerus
hello dear
As your question i am giving you a brief answer
Mid-shaft humerus fractures occur away from the shoulder and elbow joints. Midhumerous injuries/fracturs are commonly associated with injury to one of the large nerves in the arm, called the radial nerve.
Usually radial nerve cause this injury and make the wrist and elbow twist or pain.
Hope this answer will help you. if so, please kindly rate it.
regards
1helpful
II bought a telescope Edu Science Star Gazer 70MM for my children, and in the seeker the images are seen upside-down. It is normal it or the lenses are defective? It is the first telescope and the truth is...
Astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but one wouldn't bother to do this with the small finder scope.
You might like to visit an excellent website for first time telescope users at THIS LINK
Bought second hand no instructions for set up
You will NOT find a manual for this telescope being sold by Toys R Us. Possible to go visit a store and maybe they will let you copy a manual.
When you set the tripod up 2 of the lugs have broken from where the accessary tray fits,one arm to one lag,its where it attatches to the legs
Contact Meade directly and see if they have a replacement tray.
http://www.meade.com/support/index.html
or build one to fit from a piece of wood or metal.
Wiper arm where it is telescopic throws out too far when operated
The mechanism consists of the main turret, a short sleeve cover that moves with the wiper and the wiper support arm. The short sleeve cover is simply clipped on top and bottom, ease the cover apart to un-clip and lift upwards towards the wiper to free it from the wiper spring hinge. Exposed beneath you will now see a 5mm Allen bolt that retains the wiper arm on the 'telescopic' shaft. Remove this bolt, lift the wiper arm away from the glass on its spring hinge and then pull the wiper assembly off the telescopic shaft. Some real effort may be required here, but it will come free eventually. The turret cover is clipped on top and bottom and loosely around the telescopic shaft bearing. Once exposed you can see if there is any fault by switching on the wiper motor and watching the motion. It is a beautifully elegant design and is very well engineered. I have never known for this mechanism to go wrong (but there is always a first time), it only requires the very clean and occasional grease up. You said the the telescope throws out too far, is it that the wiper blade is hitting the edge of the screen at some point. I would suspect that either the blade fitted is too long or the the wiper blade pivot mount clip to the end of wiper support arm is either worn or is incorrectly fitted. Refitting is the reverse of the above
Is it possible to set up the meade telescope ds-2114ats-lnt to have it set up outdoors and view indoors. Set up remotely in other words. I have the cables and software to navigate indoors but still have to...
It may be possible but expensive. You have to be able to control the scope remotely, AND transmit the image in the eyepiece inside.
Both are possible, however expensive, more than you paid for the entire telescope!
1helpful
2answers
Glasses on top shelf
possible grit you are feeling is from the water softener breaking down. the softener contains a brown resin. this ofted happens if you have connected supply to hot water. best connect to cold
Top Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you an Optic Expert? Answer questions, earn points and help others
