SOURCE: Fidge is icing up inside on the rear
Defrost problem, advance into defrost to see if heater comes. If it does replaced timer, if it doesnt you will need to check heater and defrost thermostat.
SOURCE: too warm
First of all check to see if the compressor is running. If it's not running and you have no leakage of refrigerant. it is probably the start relay at fault, or the thermostat control is faulty. Check with a multimeter on ohms and check between common & start see what ohms it reads then check between common and run. see what that reads. then check between start and run, this should read what the other two read added together. if you have no readings then the compressor may be burnt out.
Testimonial: "thanks, i will try this out!"
SOURCE: samsung rsh1nhmh loud noise from fridge side .
Same problem, phoned samsung and was told an engineer will come and fix my fridge freezer free of charge as it is a problem with all these models. 0845 726 7864 uk number option 4....
SOURCE: Trouble with my Samsung RSH1NHMH fridge freezer
Hello
I have a Samsung RSH1NHMH fridge freezer unfortunately the fridge part will now only go down to around 6,7 degrees we have defrosted the unit but this has had no affect can you help.
Regards Sean
SOURCE: the door handle on my
You will see a small hole on the underside of the handle at the two points that the handle touch the fridge door,put a small straight nose screwdriver in this hole and turn 90deg which will expand the metal clip inside at the same time pull the handle away from the door and it will come off.You can then screw the handle holding clip into the fridge door and then push the handle back on.
